Question. I have an outbuilding that is currently being fed by a 3 wire service directly from the meter can at the house underground and into a main breaker panel with 2 driven ground rods. The panel serves as the service disconnecting means with a main breaker(neutral bonded to can). Customer is going to be installing copper water line, and RG6 cable to structure and adding a small kitchenette. My question is does the copper need to be bonded, and if so does that change how the current panel configuration is set up? Do the neutrals and grounds need to be separated at that point? Seems as though I encountered this years ago, but don't remember the solution. Thanks.
