Irving LaRue
- Warrenton, Virginia
- Electrician Apprentice
I became an electrical apprentice about a year ago. My uncle, who has been a carpenter and handyman for over 40 years, had a dispute with me regarding the necessity of the grounding/ground/green wire in a circuit.
He insisted that the grounded/neutral/white conductor was sufficient to ground a circuit and the grounding wire wasn’t really necessary. He told me, “they both go back to the same place in the panel”. Of course, he’d hook it up where available, but didn’t see the need in re-wiring the house from wires without ground to newer wires with ground.
What is the difference between the function of the neutral wire and the ground wire? What function does the ground wire perform that isn’t present in a circuit with only a neutral and no ground? What changed in electrical circuits when the ground wire was added?
Thanks for the help!
