In the past I've always just added the supplemental grounding electrode rather than testing but recently I purchased a tester because a service I installed was surrounded by concrete. Since then I've done several and installed one electrode because the ground resistance test was well under the 25 ohms required. One inspector took my word for it that the test passed and didn't require anything further. Another inspector said the panel had to have a green label placed on it with the ground resistance, date, and contractor name. I haven't found this requirement in the code book but if it is I'm wondering what the requirements are for the label. If it's in the book can someone tell me where?
Thank you.
Thank you.
