millstrainer
According to Article 250.66(C), the Grounding Electrode Conductor (GEC) does not have to be larger than the conductor used to make the grounding ring. In the 2002 NEC Handbook, the picture, Exhibit 250.29 shows that the GEC or bonding conductor that is connected to the Ground Ring has to be "Not less than the Ground Ring". Where in the code does it say the bonding conductor or the GEC connected to the Grounding Ring cannot be less than the size of the Grounding Ring?
