mdshunk said:I think the one's I normally use have "DB" embossed on them. I can only assume that's for direct burial.
TOOL_5150 said:Likewise, They have DB stamped on them, and the little plastic package I get mine in state "direct burial" on them. I just had an inspector grouch that I should leave my rod sticking up a few inches. I told my supervisor, who was at the inspection, the nec states 8' IN THE GROUND. I went by the nec, and the acorn was listed for its environment.
:roll:
~Matt
cowboyjwc said:I believe that most if not all acorn clamps are approved for direct burial. I did see a picture of a clamp that was not listed for inbedment that was almost gone after only six months in the slab.
I'm not sure that I've ever seen an acorn clamp that wasn't marked DB. There might be some, but I can't recall having ever seen any. The "water pipe" clamp type can easily be either way. The one's that look like grey pot metal are never marked for direct burial, in my observation.Jim W in Tampa said:So do you now check everyone to see if it says db ?
celtic said:Is an "acorn" rated/suitable for direct burial/contact with earth/concrete?
frizbeedog said:Is it rated for rebar connection as in the picture...? (I'll assume it is since the image you posted is from erico)
quogueelectric said:Just stick a piece of scrap pvc in the ground 6-12" to sleve the groundrod.
celtic said:The picture was for illustration only.
What brand rod/acorn is used - anyone's guess?
