racerdave3
- Western Massachusetts
I have an upcoming job where the homeowner has installed a metal building that will be used for a garage on his property. The garage is for personal use and the calculated load for what he has proposed is moderate at best. I am running a conduit from the main panel in the house (200 amp) out to the building and installing a 100 (sub) panel out there. Of course because of the application I will be running 4 conductors with a separate ground and neutral. Now my question in in regard to grounding out at the building. Should I drive a ground rod at the panel location and hit the panel, or drive a ground rod and hit building steel, or hit the panel and the steel as well for bonding purposes? Along the same thought process, is one rod enough or would it be better to hit 2 corners of the building? I have heard much debate about these situations, when running a 4 wire service out to a building that has the separate ground, then driving a rod and creating a parallel grounding situation.
