What do people think about the practice of installing a ground rod at a concrete parking lot light pole base? My take is that the metal pole should be bonded to the building power system, and an additional ground rod in this position is not adding anything. In addition, a concrete pole base, with encased rebar, is inherently grounded and is a lower impedance ground than any ground rod. The pole, being bolted to this base, has a pretty good place for a lightning strike to go (a parking lot pole being a good lightning rod) and the extra ground rod is superfluous. What do people think?
