Hello All,
We are manufacturers and exporters of “ Copper Bonded Ground Rods “ with UL and RUS approvals. Have recently developed some accessories complimentary to above product – Ground Rod Clamps and Couplings.
We now need to submit parts for UL approval and listing. Are not able to correctly figure out the conductor sizes mentioned on the Clamps i.e.,
Need your assistance in clearly defining what it means and also which cable samples in both types – sold and stranded, to be used for testing.
Also, is “short time current test” needed for Clamps in UL ? Kindly let us know the applicable tests for Ground Rod Clamps and applicable UL standards ?
Thanking you in advance for your cooperation.
A rapid response shall be highly appreciated.
Cat No. | Trade Size – Inches | Conductor Range/Size |
KRC12 | 1/2 | 8 sol – 6 str |
KRC58 | 5/8 | 8 sol – 6 str |
KRC34 | 3/4 | 8 sol – 6 str |
KRC38 | 3/8 | 10 Sol – 4 Str |
KRC1 | 1 | 8 Sol – 4/0 Str |
KRC12 Heavy | 1/2 | 10 Sol – 2 Str |
KRC58 Heavy | 5/8 | 8 Sol – 1/0 Str |
KRC34 Heavy | 3/4 | 8 Sol – 1/0 Str |
