s-park-er
- Oroville, CA
- Building mechanic - specialty problem-solver.
I am installing Automated Payment Machines outside our park entrance kiosks. They are essentially a metal cased ATM machine bolted to a concrete pad. The machine is about 10' from the building, fed by a single 20A GFCI protected circuit, and has a data / phone line which also shares a trip signal for the building alarm system. There is no structure covering it, and this is a lightning prone area. Do I need a separate ground rod at the machine as I would for an outdoor luminaire or is the EGC enough?
In another installation, the machine is right against the building, under the eave. Any different need for that one?
Thanks for your input!
