dburney
- Brooklet ga usa
I have 6 structures that have a mini power panel/transformer combo that has 3 phase 480v feeding in an underground PVC conduit that come into each mini power panel and then the electrician has used Polaris lugs and tapped off with 2 legs to feed panel transformer primary. They loop in and out of each panel at each structure this way with 3 hots and 1 grounding conductor and feed all 6 mini power panels with 2 of the hots. Please help
I have 2 questions.
1. Is this legal to tap in a panel this way with Polaris lugs and loop from panel to panel?
2. Is it required to install a ground rod at each mini power panel? They do have the mini power panel bolted to the structured steel that is attached to a ground rod. However I don't think this is an approved method.
I have 2 questions.
