rob-1
- California
Can a ground rod be used as follows for this situation?
House has mostly 2-wire (no grnd) wiring except for bathroom ckts. Same in garage.
Thinking a ground rod outside of garage wall wired to washer & dryer duplex 120v ckts for temp grounding until new 12/2 nmb cable (w/ground)is run from panel to garage. No other grnds either from panel, existing 2 wire (of course), or anywhere else are feeding the attached/stucco/with aluminum siding wood framed residential garage.
Rob-1
Rob-1
