nietzj
- St. Paul, Minnesota
- Electrician
I need to ground a transformer, there is no building steel in the area so I'm looking at other options. This is an interior location but is on grade level. Would it be acceptable to drill a hole through the concrete and set a ground rod ? 250.53 (A) (1) tells me "If practicable install below permanent moisture level" Not sure if 50ft from the exterior of a building would be a good ground but if I can achieve 25 ohms or less I think this is an acceptable installation. Anyone ever done this?
