ground rod required for small sub panel ?
I think two ground rods will do it. If the gate has a footer with rebar, do you need a ufer ground?
The reason the exception was added for a luminare pole was that debate on if the pole was a structure. So that debate was ended, anyway
More the reason was the definition of 'structure' , than that of the theory of an inclusive GE to a structure is the point Tom
~RJ~
