infinity said:Since you're referring to the 25 ohms or less on a ground rod then it would be up to the AHJ. Some may allow you to perform the test others may not. This is one reason why many of us simply install two ground rods and walk away.
tom baker said:It requires either a clamp on ground resistance tester, or a 3 pole fall of potentail tester. For a single ground rod, you'd want the 3 pole tester.
Probably $800 and an hour to do the test.
"Drive two and go home"
