Ground rod
St. Louis
Maintenance electrician
Is their a limit to how close to the foundation you can install a ground rod . 2020 nec. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If you're close to the stem wall you're more likely to run into the footing, and if you're too close to the footing you may run into the footing drain.
Rob G
Seattle
