A four family townhouse, with 3-hour rated partitions between units has a single location with all the electric metering grouped at one spot. The meter bank is fed from a single service lateral from the transformer. There are no disconnects or overcurrent devices at this location. There are four service laterals leaving the meter bank, which continue outside the building and enter each dwelling along one back wall. Each dwelling has a main disconnect panel in each cellar containing a two-pole 100-amp circuit breaker. Each main panel is bonded to each dwelling unit?s water main within five feet of where the copper water pipe enters each dwelling.
Where are ground rods required? Should there be 8 ground rods outside, 2 at each panel location, bonded at the same location as the water pipe? Or, may we install only 2 ground rods at the meters?
Are we allowed to have 4 services in this building? Or, should there be one service, with four meters and disconnects grouped together?
