WV Sparktition
- Charleston, West Virginia
I have a dual lug 320 amp meter base, and i am feeding two 200 amp main breaker panels on the inside back wall. (less than 3 feet)
question is:
Our PoCo needs two ground rods for any service in addition to a cold water or other method. Does that mean i need 4 total ground rods or connect continuously through both panels that are side by side and then to 2 ground rods to save cost.
Also, since the panels would be 200 amp, can i still use #4 bare copper to ground it, or does it need to be rated for 320 amps?
We had talked about putting two main disconnects outside for ease of grounding, but no need to put them because we are less than 3 feet inside.
question is:
