sv650k4
New member
- harrisonburg va
So i have watched mikes video on grounding and bonding. It makes great sense until you get complicated scenarios. a Project i am working on is a 200 amp service at a home. The customer is going to be adding a generator in an outbuilding that has current electrical service. 60 amps off the main panel with a floating neutral and no ground rods at the building. The plan is to trench a piece of 200amp mobile home feeder back to the meter base and install a manual transfer switch. Would i be correct in grounding the generator only at the service entrance and not at the generator 150 feet away? Second being an outbuilding is it correct on not having ground rods?
The second thing the customer is having be do is install solar panels on a ground mount set up approximately 150 feet away. It is a transformer style inverter that has you ground the panels negative lead to the earth ground on the inverter. I was planning on running THHN in conduit back to the main panel and having the ground tie in to the main service entrance. I have some people say ground rods are required at the panels as well but i wasn't so sure about this.
Any help would be greatly appreciated.
