mbrooke
Batteries Included
- United States
- Technician
What functions do ground rods provide at the service?
I keep hearing from computer engineers and electronic techs ground rods absorb static, radio interference and common node noise. Having extra ground rods and meshes fixes these problems.
An example: "Lost earth ground or high impedance to earth ground can cause problems, even in residential electronics. If you cannot divert the common mode noise to ground that is produced by most home electronics, all you're going to do is pass it around. If you lose your ground, you will have a lot of noise running around your electrical on into your electronics."
"A poorly grounded system cannot allow the electronics to divert noise through the ground, so it generally hangs around and gets into other circuits."
Is there any truth to these claims frequently made?
