Twoskinsoneman
- West Virginia, USA NEC: 2020
- Facility Senior Electrician
another weird question. Would you accept a hinge as grounding the door of an enclosure. We use nylon washers to screw our panited enclosure doors closed. The painted door is mated against a painted frame. The only place you would get metal contact is through the stainless steel hinge. Is grounding through a hinge good enough?
I remeber as an aircraft mechanic the flight surfaces always had bonding straps crossing the hinges. Also I have see this on commercial enclosure doors.
