Ground Wire for GFI Receptacle Running in EMT Conduit
Samardas
Los Angeles, CA, United States
Electrical Engineer
Do I still need to run a separate ground wire for GFI receptacles if I am using EMT conduit? Can I connect each GFI receptacle from the conduit locally since the conduit is run from the panel which is grounded already? Thanks a lot for your help! Please stay safe!
