wrldtravlr0612
Here is the situation. I have a 5KVA system with a Voltage Regulator and a UPS. The system is powered from a Main Distribution Panel. The entire 5kVA system is bonded and grounded. The ground comes from the UPS Bypass switch and is terminated back at the ground in the Main Distribution Panel.
Here is my question.
Can I run the feeder wire from the Main Distribution Panel and the Ground wire from the UPS to the Main Distriution Panel in the same EMT Conduit?
It is my understanding that it can be done, as long as the Ground wire going to the Main Distribution Panel is bonded at the beginning of the conduit run and at the end of the conduit run.
Please help, I have 5 different people telling my 5 different things. If you could, please provide the NEC reference(s) also.
