Grouch
- New York, NY
Hi,
In NYC, let's say i have 2 service switches that tap off from a Service End Box. on the load side of each switch, you would size the grounding conductor based on the fuse size of each switch (and then upsize for any possible voltage drop). however, how do you size the ground wire between the Service End Box and each switch (line side of the switch)?
