buddyearl
- Hermitage, MO
- Teacher
I currently have a detached garage panel that is fed by three direct bury cables which run from a sub panel. I need to add ground bars to the sub panel and the panel
in the garage. Currently the ground and neutral wires are in the same bar. Can I use a bare copper ground wire to run from the main to the first sub panel and then
to the garage panel. The run to the garage is 48' with 6' of it under ground. Most of it is under a crawl space.
