Part VII. Grounding
610.61 Grounding. All exposed non–current-carrying metal
parts of cranes, monorail hoists, hoists, and accessories, including
pendant controls, shall be bonded either by mechanical
connections or bonding jumpers, where applicable, so that the
entire crane or hoist is a ground-fault current path as required
or permitted by Article 250, Parts V and VII.
Moving parts, other than removable accessories, or attachments
that have metal-to-metal bearing surfaces, shall be
considered to be electrically bonded to each other through
bearing surfaces for grounding purposes. The trolley frame
and bridge frame shall not be considered as electrically grounded
through the bridge and trolley wheels and its respective
tracks. A separate bonding conductor shall be provided.
