Ground
wireday
New England
Master electrician
Omron limit switch ZE-NJ-2S will be used on overhead door, It has a metal body but no place to attach a ground wire. Any ideas on grounding? Is it allowed to let the door track its screwed to be the ground?
If you use a raceway that is compliant as a ground- Like emt then the unit is grounded. You can also drill and tap a hole.
Is it low voltage, if so it is a non-issue
If this limit switch is mounted to the overhead door frame that is bonded and grounded, does that provide a acceptable eg?
