Tanderson2100
New member
I have a inspector that Red Tagged me for terminating the grounded and equipment conductors on the same buss in a 200 amp 240 volt service main panel of a house. The panel has two busses on each side of the panel connected by buss bar and the bonding screw on one side. The inspector said since the bonding screw is on one side and neutral conductor from the riser is on the other side even if there are connected by a buss the grounded conductor needs to be on the side thst the netural conductor is at and the grounding conductors on the side that the bonding screw is. Is there a code refrence too this.
