Originally posted by Nick:
You say this is customer installed from a utility pole. Where is this system metered? The rules change depending on what side of the meter or service point we are talking about. How is the system you are connecting to configured? Is it ungrounded? Is it a common neutral muti grounded system?
250.24(B) specifically states it applies to grounded systems operating at less than 1000 volts. It does not apply in your case. Can you supply a little more info on the system you are dealing with?
Bennie,PGE, SoCal Edison, PP@L, and many other utility companies retain authority on feeders of this voltage. It is a legal liability concern.
