hhsting
- Glen bunie, md, us
- Junior plan reviewer
Nec 2014 Article 250.186 mentions grounded conductor. What is grounded conductor?
Grounded Conductor. A system or circuit conductor that is
intentionally grounded.
I apologize but I still don’t follow. In context of NEC 2014 Article 250.186 does grounded conductor mean neutral?
Neutral Conductor. The conductor connected to the neutral
point of a system that is intended to carry current under
normal conditions. (CMP-5)
Neutral Point. The common point on a wye-connection in a
polyphase system or midpoint on a single-phase, 3-wire system,
or midpoint of a single-phase portion of a 3-phase delta system,
or a midpoint of a 3-wire, direct-current system. (CMP-5)
Informational Note: At the neutral point of the system, the
vectorial sum of the nominal voltages from all other phases
within the system that utilize the neutral, with respect to the
neutral point, is zero potential.
