Minuteman
- The Sooner Nation
I replaced two Analog Intermatic time clocks with a Digital Intermatic timer for a customer today. The Main Pump and the Vac Pump on a 2P20 and the Hot Tub Pump on another 2P20. The timer has a temp probe to bring everything on to prevent freezing. All three have just one leg being opened through the timer.
As I tested everything, and the Hot Tub pump would run on 120v when the timer switch was open. The motor was shorted to ground but was not tripping the breaker. Even amped the ground wire and it was pulling 29 amps. Told the customer that the breakers should be GFCI and that he is lucky to still be here.
My question: Why didn't the breaker trip?
