Grounded (Neutral) Conductor
cooldad
Hello,
I am trying to find out if it would be acceptable to Run a 3ph 3W feeder from a 3ph 4W MDP panel (120/208 wye) to feed a bank of airconditioning units - no other type of loads. i.e would I need a neutral as part of the feeder or is the neutral a requirement of the code. If the neutral is needed then is there an engineering formula that can be used to determine the size of the neutral conductor for such application?
Grateful if anyone can help with this!
Thanks
