Hi, new to these forums and I am not sure if this is the right place to post. If no please suggest the right category.
The question is this: I am working on a piece of industrial equipment (testing machine) that is wired for 208 3 phase input. When this equipment was originally built it had a 3KVA transformer built in to convert to 120V internally. The only components left in the equipment that need 120V are a few small DC power supplies (<100W) and a laptop power supply. All of these are plugged into a power strip that is attached to the 3KVA transformer.
I would like to pull the big transformer out and just grab one leg of the 208 input to feed the power strip. The fourth leg (grounded neutral) of the 208 is bonded to the steel cart that is the frame work for this equipment. Is it ok to tie the neutral line from the power strip to the ground connection in the cart?
If not, is it ok to remove the ground connection to the cart and float it?
Thanks
Thanks
