EE_FSU
- Anchorage, AK
I can't decide whether or not the secondary neutral (on a delta-to-wye isolation xfrmer) should be bonded/grounded to the panel chassis or left ungrounded. It appears as though NEC 250-20(D) (separately derived systems), which applies to 250-20(B) (AC system of 50-1k volts), provides insight. I don't understand what is meant in 250-20(B)(2) by "circuit conductor" though. Also, note that earth ground is not an option - has to be bonded at the panel (if it is to be grounded).
