sogelectric
New member
- Orlando
I recently installed a service for a 480V 3 phase motor which is fed from a step-up transformer; Primary 208V-Secondary 480Y/277. The 208V 3 phase system comes from a transformer into a meter, from there into a 208V disconnect then into the step up transformer then into a 480V disconnect. From the 208V transformer I have 3 hot?s and a ground/grounded conductor going into the meter. Leaving the meter into my first 208V disconnect my grounded conductor is tied to the equipment and leaves to the transformer still 3 hot?s and a ground. Going into the transformer should this ground wire terminate at the frame connection or the XO or does it matter since it is all tied together? Once I leave the step-up transformer to go into the 480V disconnect do I need to bring in 3 hot?s a neutral and a ground in which I would isolate the neutral, or can I just keep 3 hot?s and a ground because I?m just using the 480V for a 3 phase motor and don?t need a neutral? If I use just 3 hot?s and a ground to my disconnect, the ground that goes out of the disconnect to my motor, would it be considered a grounded or grounding conductor?
FYI: My meter base grounding electrode conductor goes out of the meter connects to one ground rod then to another one, then into the step up transformer equipment ground.
Thanks
Thanks
