Hi all.
I have a question and will get straight to it.
When researching what size the Neutral should be on a simple 200A, 3-wire, 240/120V service, I found myself going around in circles.
A lot of people point to Table 250.66 Grounding Electrode Conductor for Alternating-Current System, but when I look into this, it seems this is a dirrenert conductor altogether. This conductor is only for the ground installed on a bus bar that the Service Neutral is also installed on, and ties to a ground rod, water pipe, or steel structure.
Other people point to table 250.102(C)(1) Grounded Conductors... etc. However, I believe this is for a neutral conductor that is not part of an incoming service, that is why I believe they left out the word "Service" in the Grounded Conductors title.
My question is, can someone point me to a chart that clearly outlines what the Grounded Service Conductor size needs to be? Or that the GEC is the Grounded Service Conductor.
Thank you in advance.
