powerplay
- In front of a computer.
An Point to Point Radio mounted on 2” EMT has an #6 insulated copper wire back to the trailer subpanel inside the EMT pipe along with Ethernet cable through an 2” weather head to the radio. The metal EMT Mast is attached to the Trailer standing 6’ above the roof, but isolated from the support and Radio by rubber and vinyl tape where clamped to be able to provide an separate #6 insulated copper wire to it’s own ground plate.
If lightening did hit the metal EMT support, would the isolated path of least resistance actually reduce damage to the trailer, or likely blow the metal EMT support off the metal clad trailer and damage everything anyways ?
Thanks for any feedback !
