Jbyars
- Sunray Texas
- Associate Electrical Engineer
I am designing a new 240VAC 3 Phase system and was trying to determine the proper way to ground the system.
Our system will be composed of a Delta-Delta transformer and a single panelboard.
At the transformer will be the GEC and the grounding electrode(ground rod).
Could I install a separate ground bus bar in the panelboard and bond the neutral bus bar to the ground bus and run a single bond conductor from the ground bus to the transformer ground bus bar to ground this system and establish the neutral?
