i am installing 5kv transformers outdoor to feed spray gun controllers and valves inside of wetting station vaults around the perimeter of a loadout pad for fgd product of a power house. my approved drawings dont show a detail on the grounding of these tranformers. they are a square-d one-piece unit with the panels made on them. they are fed with 20 amp double pole 480 breakers and have a 30 amp 120/240 secondary main. I'm wondering if they will require a ground rod at each station to bond each secondary xo to ground or if the ground coming with the 480 feed is sufficient? Ive never hooked up transformers this small, i didnt know if the rules were the same. there is nothing in the prints or in the papers with the transformers. nec wasnt clear on this situation
