I am installing a 600 amp single phase service for a customer. The poco has the CT and meter on the pole and the a 600 amp disconnect is located on the outside of the building, the 600 amp panel is located just inside...
My question is about grounding the primary disconnect. Do I run my grounds from the water line, footer and ground rod into this disconnect, or do they get connected inside the panel.
Seems like the grounds would go to the disconnect, but any advice would help...
http://imgur.com/a/xGQRG
