Grounding a concrete tank
cornbread
I have a problem, we have been asked to come up with a grounding scheme for a concrete tank. Normally no problem, slap a few ground rods and cadd weld to the rebar. Our civil guys have spec-ed out the rebar as epoxy coated and that is my problem, attaching to the rebar won't work. Anyone else encounter a situation like this and how did you get around it?:dunce:
have them add some uncoated rebar just for you to connect to.
why are you "grounding" a concrete tank? and what are you "grounding" it to are important questions to answer first though.
