I have installed a 3" conduit to supply a panel. It starts from the swith gear with the 1st 90 and 12" of conduit imbeaded it concrete. i had to use a short section of flex to enter the panel. My question is do i have to use grounding bushing on the supply side. i am not using concentric knock outs. Inpector says due to the fact i have used flex and its over 20 amps i must use grounding bushings. I cannot find it in the code.
