chiefelec
I hope some one can help me with a disagrement I am having with an inspector. What I have is a trailer mounted 410KW gen set. the grounded bus and grounding bus are bonded together. there is a grounding electrode conductor running from the grounded bus to the frame of the trailer. there is a second grounding electrode conductor attached to the trailer at the same point as the first, this conductor is then attached to two 8 foot ground rods.
the dispute is the inspector has directed me to connect a continuous conductor from the ground rods to the grounded bus.
electricaly I do not think it makes a difference. but this is a portable gen set.
