Leo1
- Los Alamos, NM
When installing a supply-side disconnect to feed a new PV system the NEC states a main bonding jumper must be placed between the grounded conductor and the equipment grounding conductors at the first disconnectin means of the supply. However on a PV system the first disconnecting means of the supply is usually near the array of multiple modules and inverters which are often hunderds of feet from the main utility and the new supply-side disconnect. At which disconnect on the new PV system is the grounded conductor to be tied to the equipment grounding conductors - at the new supply-side disconnect or the source of the PV power? Likewise where should the grounding electrodes be placed at the new suppl-side disconnect or the source of the PV power.
