tim89s
- Brush Prairie WA
I am installing a 125 amp 480 volt main lug panel. This panel would be fed from the main
service. Out of that panel I want to set a 15kva 480v pri 120/208v sec transformer. There is no
grounding electrode remotely close. I came across code section 250.30a5 exception2. Can I use this exception if I change the main lug panel to a main breaker panel suitable as service
equipment?
equipment?
