Is it permissible to take a grounding conductor entering a metallic weatherproof box, strip a section of the conductor to wrap around the pinch type grounding screw typically found in weatherproof metallic boxes such as bell boxes while leaving a tail of 6-8 inches outside the box to make-up under a wire nut with the other grounding conductors entering the box?  would not this be a better bond since the grounding conductor entering the box is continuously bonded to the box by wrapping it around the ground screw first?
[ July 13, 2005, 06:44 PM: Message edited by: al21can ]
