I wired up a 1000 gallon above ground gasoline tank today. Its feed is a 208 volt 20a circuit fed from a sub-panel. The tank is grounded with a #12 ground wire from the panel. The mfg is saying I also need to drive a ground rod at the tank and ground to it also. Is this against code as the tank is already grounded from the electric circuit from the building?
