Grounding acceptable ohms readings
Ainsley Whyte
Jamaica
Senior Electrical Engineer
I have ground a Petroleum Tank, what is the minimum acceptable resistance readings for the grounding as per the code?
What do you mean by ground the tank is it being connected to grounding electrode?
The NEC would consider this an auxiliary electrode with no minimum resistance or min GEC size.
Is this grounding for lightning protection?
