CaliforniaMike
Hello,
I recently was asked to look at a heating assembly that is used in a production plant. The original request was to evaluate the strain relief and propose a new way to assemble the cable to increase the life of the cable. A quick look revealed that there is no ground wire to the assembly. This is a 115 VAC heated core that pulls about 0.6 A nominal. Operators are in contact with the assembly while live...
My question relates to the proper way to attach a ground lead to the assembly. There are two halves; each will need to be grounded. However, they are thin. I am tempted to use a #10 stainless screw and a SS external lock washer. However, these are not listed parts. On top of this, the assembly body is aluminum. I am not sure where this assembly would fall under NEC. What are my options? Can anyone suggest a listed, but very compact grounding system for a device that only pulls 0.6 amps?
Thanks,
Mike
Thanks,
Mike
