Would like some clarification if someone can help. I am replacing 2 wire outlets with 3 wire outlets in existing home. I plan on running a ground wire only to each outlet. Do I need to run EACH wire back to main panel, or can I daisy chain in J boxes?? Also-does the groung wire need to be in some type or raceway or not-Thanks for your help from first time poster
