I've gotten several different answers on how to do this, would greatly appreciate the help!
So there's a main service at a building with a ground to neutral.
we're tapping off our main solar disconnect some hundred feet away outside line side of the service (the service is inside a building).
would a ground electrode be required to be installed at the solar disconnect, or must it be a direct gec to the existing ground rod? would we run a ground wire to connect that ges system to the main service ges, how would we do that? or does the neutral count as what ties the two ges systems together?
Can't find any code articles that say one way or the other, once again really appreciate the help!
